While waiting for the cockpit carpet contact cement to set up I spent a short amount of time mounting the Bilge Pump to its Mount Plate Step 9 and the Hull Mount Angles to the Boom Tube Step 10. No problems encountered here though I wasn't sure exactly where to place the pump housing on the end of the plate (housing aligned right to the end) and on what end of the rivets to place the washers (pump plastic housing side). I decided not to actually install the pump in the hull until I have the airframe in place as I don't know how far forward the pump Mount Plate has to be so that the removable screws Step 9.2 are accessible.
