Basically got it unloaded today. Fixed my air compressor with a bad switch, found and put together the rivet gun and moved things around. There will be much to do to get organized, and I need to use the crate lid for a worktable. Then, perhaps, I can get started. Only a few parts were damaged: Wing skins, vertical tail fairing, small and likely reparable damage to the cowling from the box getting crushed. Some are slightly bent parts that should be easily straightened. Not end of the world, but the shippers will be settling my claim. This was perhaps the only bummer to an otherwise happy event.
