Trial fit wings together; minimal cleanup/enlargement of spar stub bushings required to permit spar pins to fit comfortably.
Started airbrake fabrication/installation. Push rod from wing root to airbrake box is _not_ cut to the correct length; must be removed from wing to trim it. Queried "the world" (my Apis builders e-mail group) about the appropriate adjustments required.
