Brief Description: Machining rear suspension mount
Get it setup and level, double check reference marks, then begin drilling out the hole. The final size is 1.46" Placed a solid screw jack under the tube to support the load of the drilling, don't want the setup moving, opened the hole to 1/2 with drills. Used 3/4 end mill next then used a boring bar attachment to get the final size. Not quite there yet, taking a break.
