Fabricate a Bracket Locating Bar out of 1/8 to1/2 inch thick metal/plastic/wood. Material is not provided in the kit. The bar simulates the compressed C-1016 Gas Strut and is used instead of the gas strut to locate the C-1013 Gas Strut Attach Brackets on the inner surface of the C-1002-UR Door.
Fabricate four C-1016B Bushings from AT6-058 x 5/16
Break apart the C-1013 Gas Strut Attach Bracket into it's two halves and smooth the edges.
Insert a C-1016B Bushing in each end of the Bracket Locating Bar and attach the gas strut attach brackets to the bar using the AN3 bolt/washer/nut. Attach the bracket locating bar to the WD-1023 Gas Strut Attach Bracket using the AN3 bolt/washer/nut.
It was getting late and I stopped short of match drilling the holes into the right door.
