I finished the ELT wiring today. I re-ran the wires through a better spot at mid cabin along with the tail strobe and trim wiring. I connected the molex pins on the ELT wiring to the remote switch and tested it. It works!
I then moved on to the wiring for the pitch servo. This I ended up running under the floor where the battery cable would have run if I were going to have an aft mounted battery. I secured the wire using 3M adhesive tie wrap achors.
