Today I began work on installing the stiffeners in the rear fuselage in accordance with SL-00014. I marked holes as called out for in the service letter and then drilled the first holes and clecoed the stiffeners to the outside of the fuselage. Then I drilled the rest of the holes using the stiffeners as a guide.
