Brief Description: Magnetometer and VOR/ILS antenna
I finished mounting the magnetometer and began working on the wing tip VOR/ILS antenna. I drilled out the rivets on some of the plate nuts in the wing tip so that I could mount the ground plane of the antenna under them. Then I drilled holes in the ground plane matching the plate nut holes.
