Tonight I worked on the scarf joints for the left wing. I made this more difficult for myself because I followed the order of the instructions and dimpled the skins first. The scarf joints would have been much easier to do before the dimples were done. I tried using a file at first and couldn't get it to work. I ended up using a sanding drum on the dremel and that worked great. I just used the calipers to measure the thickness every so often so I didn't take too much off. The scarf joints on the right wing came out well. On to the left wing.
