I worked on mounting the magnetometer today. It is mounted in the right wing tip. I cut a piece of aluminum sheet to fit over a lightening hole in the wing tip. Then I drilled holes through the aluminum strip to provide mounting holes for the holes on the magnetometer. I used brass screws to mount the magnetometer to the wing tip.
