I took a little time over the Holiday weekend to install the Side skirt braces. Howard and Mom were down for a couple days so HT helped me with the skirts. First we mounted the brace to the frame and drilled the holes then cleco'd. Once you have the brace mounted to the frame I placed the canopy back on the Fuselage so that I could see how the fit was. You can get a better fit against the fuselage if one of you push the side skirt in from the outside while the other person match drills the bottom holes in the brace from the inside. I'm still going to bend the skirts to get a final fit later.
