Installed the Left and Right C-759 inside skirts and drilled them to the Canopy/C-660 outside skirt. The skirts get cut at the front bottom so that when the canopy slides back, it will clear the fuselage side. I made a undersize cut first then trimmed it as needed so that it will clear the deck and side of the fuselage. I then cut the C-791 skirt braces. These two receive 10 each lightening holes (1 1/4") first then get small slits at the bottom of each hole. This is so it can make the bend of the outside skirt. Be carefull of where the #30 holes are on the C-660 or your slits will come out right on top of them.
C-759, canopy and C-660 drilled together.
Here is the trimmed side skirt with the canopy back. When forward it lays on the deck.
