Switched over to the side skirts for a change plus Sherri was available and was more than happy to assist. We layed out the Skirts and drilled the holes that attach the skirt to the frame. We then fit the skirts to the frame then matched drilled into the side frame. This is where the instruction say to Modify the C-759 inside skirt then lay it up against the C-660 outside skirt then match drill. Well something just didn't seen right. If I would have done it that way, the Canopy might not be allowed to come all the way down. Since I already had the Outside skirt (Left side) drilled through the frame, it was tricky trying to get the inside skirt matched up and to sit down on the frame. We did some measuring for a couple holes then just got it in place on both ends then drilled the rest. It came out good. The right side was done by first match drilling the C-660 and C-759 together then drilling the 660 to the frame. This way came out perfect. Sherri is learning fast why some of this stuff takes so much time the first time. You really need to try and stay ahead of what is going to happen.
Sherri clecoing the skirt. She spent alot of time with me tonight.
