Removed the Canopy from the Frame after drilling #40 holes. Trimmed more off the rear duck tail so that the top skirt will fit better. In the picture below I attached the top cover strip and back drilled through the previously drilled holes in the canopy. This will be riveted to the Frame and canopy and cover up any imperfections around the canopy latch handle. Next I began marking the holes for the side skirtsl As you can see in the 2nd picture, there are many holes for the rivets and the Screw s that secure the canopy to the side rail.
