It was time to drill some holes in the canopy. After many days of bending and rebending I decided it was time. The first picture show how I put masking tape on the frame so that the touch points could be seen through the Canopy. I started at the Middle and worked my way to the rear. Once I got to the rear I alternated from Left to Right down the rear Bow to the horizontal frame. The holes are #40 to start 2" apart. They will be Countersunk later then opened up to final size. Then I worked my way back up the middle to the forward bow then down the front bows. This turned out nice. Next will be the strip down the center.
Masking tape on the frame for drilling the canopy
Half done. When you push down on the Canopy the mark shows on the tape. This is where you drill.
All done. View from the front where the Windscreen will be,
