The canopy frame needs to drop down so that it is 3/8" above the Roll Bar. This is to facilitate the meeting of the Windscreen as it sweeps up from the front. I needed to cut about 1/4" from the bottom of the Roller tube on each side. Used a Pneumatic cut off grinder then took the bench grinder to straighten it out as needed.
Roller tube on the Canopy frame front. Marked for cutting.
After the cut was made I measured it. It took a couple trim jobs to get it just right.
