Getting pretty warm (Humid) tonight but I managed to get some more work done. Fit and cut the Canopy brace. The plans say to fit it down through the prepunched slot in the F-7106 skin. It mates up with the F-7108A Rib and the Angle bracket running along the Rib. I stuck a screwdriver between the two so that the brace would slide between. It's a tight fit. If you remember when I riveted the Bracket to the Rib I installed a small washer between the two so that it created a gap. I forgot to take pictures of the part that mounts to the RIB. I removed it to debur and paint the end.
Me cutting the Brace to length
This is how it fits in the Roll bar. I clamped it and then drilled a 1/4" hole for the -4 bolt
The finished product . You can see how it runs through the Skin down to the rib.
