"THE OTHER WOMAN"
Date:  5-21-2006
Number of Hours:  1.50
Brief Description:  Brake install
OK, I feel like I did this twice because after mounting the brake I had to take it back off because the fitting at the top (90 deg) will not turn with the brake mounted. So off with it. Anyway, I need to drill the axle for the Wheel Nut. While the wheel was on and off the ground I set the bearing for the correct tightness. I tightened until there was no movement/play in the wheel. I then drilled marker holes through the Nut onto the axle. Removed the wheel and drilled through the axle on both sides.
Here it is off the ground with my simple mounting/lift pad I picked up from Vans.
Man this axle is tough.
Wheel back on with the nut and cotter pin.
