"THE OTHER WOMAN"
Date:  5-21-2006
Number of Hours:  0.50
Manual Reference:  Main Wheel DWG
Brief Description:  Brake line install
I think I'll install the brakes. Already had these installed before so the left and right were done. Just slide the main assembly over the rim with the two mounting studs then from the outside back of the rim mount the pad. Add the two bolts and torque.
