I continued the Headset/Mic cables through the baggage area with a rubber wire grommet then ran the wires up the center support with tie wrap holders. I riveted 5 of these in place to secure the wires then drilled a hole through so that the Pilot set of wires could get to the other side. Tomorrow I should be cutting these down to size then terminating them on the jacks. I need to test these to ensure the radio harnesses are wired correctly.
Rubber grommet through the bulkhead.
These are the wire tie supports
On up the baggage bulkhead support. These will all be hidden behind the baggage comp wall.
