I didn't like the weight that was causing the bundle to pull away from the radios so I added a reinforcement brace across the upper supports. It is just a .020 angle riveted in place and a nut plate so I can clamp the bundle down and take any pressure that will be pulling on the radio stack off.
All of the wires off the stack have a loop to facilitate removing the panel if needed.
