Mounted the Forward Fuselage assemble and fit the angle and Plate. Not sure how I will rivet these together since the angle is a hard to slip behine the sub panel once it is riveted to the Rib. The plans say that you can bend the sub panel to get it in there but I think after I paint this I will rivet it while it is in one piece.
