Time to filt the F-721 ange along with the F-7108B angle. These two pieces give support to the entire forward fuselage assembly/Panel. The 7108B angle at the forward fuselage mounts to the F-601 angle that runs the top of the firewall. Then the angle runs up the 7108 Rib to give the structure support. The Instrument panel mounts to the rear of the 7108 rib. This will need to support all the weight from my Electric panel.
F-721 Attach angle ready to be fit.
This is the F-7208B before it was bent and Drilled
