Before painting a few items needed to be added to the panel. I drilled the hole for the Over voltage light dead center above the Dynon Efis. Then drillled the hole for the Power outlet right above the cabin heat knob. Next I added two holes under the panel right below where the Remote ELT is mounted. I installed the 3.5mm jack for the "Music 1" iand "Music 2" inputs. These will be wired through the PS6000 intercom. Any device like an IPOD can be jacked in an the music will be pumped out to our headsets.
