Brief Description: Throttle bracing and Carb heat mount
Tonight I worked on the Throttle Quad mount. I drilled the verticle brackets for rivets. I also decided to fab a Carb Heat bracket from a piece of, I think .040 aluminum. I notched it out around the Quadrant and then put a 90 deg bend in it for mounting. I used the bolt holes from the rear Quadrant mounting. Worked perfect. The Carb heat is very easy to reach off the throttle handle.
Carb heat knob to the left. Don't know what I will use the other side for.
