Since I have the Engine hoist I decided to mount the prop myself. The hoist made simple work of this right up to the point I needed to turn the bolts into the crank. These bolts are very long but went in with the hand all the way in. They are just in a hard to reach location so your fingers get a little worn down after turning for 30 minutes. Other than that it went without a hitch. Now all I need is the extention wrench that Dick is making for me. This wrench will allow clearance from the hub for torquing.
