Mounted the Motor hardware in the Channel. Needed to remove the AN960-416 washer from the Actuator plate mounting Bolt. This was to compensate for the smaller hole on the F-760-L Cover. The bolt would have set lower the cover with the larger hole but I f
This safety wire will be replaced later. It is not correct.
