Riveted the Brackets for the Motor then Mounted the Actuator into the Actuator Channel. I forgot to dirll the mounting hole in the side of the Channel to accept the bolt head. Tthis will not be a problem, the head will stick out a bit and I will adjust
Riveted the actuator plate and angle to the upper Channel
Forgot to over size the hole in the Channel. No problem.
