306TD Web Site
Date: 11-13-2021
Number of Hours: 3.00
Manual Reference: 24iS/U-02
Brief Description: Completed Rollbar
Completed Final-Drilling #30 all the #40 holes in the flanges o fthe F-1231A-FL, -FR, -AL, & -AR and F-1231B & C. Match-drilled #30 the three holes of the C-01213A through the F-1231A-FR & -FL and underlying F-1231E per figure 2 detailed view page 24iS/U-02. Disassembled and deburred all rollbar parts.
Machine countersunk the outer flanges of the F-1231A-FL, -FR, -AL, and -AR for the CS4-4 rivets except for the holes common to the F-1231D as shown in figure 1. Then machine countersunk the C-01213A for the CR3212-4-08 rivets per figure 2 call out same page. Countersunk the five holes on the forward face of the F-1231A-FL & -FR in the detailed view of figure 2 same page for CS4-4 rivets.
Cleco'ed the F-01231F-2 to the F-1231A-AR and aft F-1231E, then match drilled #43 the switch mouting hole of the F-01231F-2 into the F-1231A-AR and F-1231E per same figure. Removed the F-01231F-2 and Final Drilled #30 the #43 hole match drilled in the F-1231A-AR and F-1231E ONLY. Deburred the F-01231F-2 and Tapped #40-40 the switch mounting hole in the F-01231F-2 ONLY.
Cleco'ed the rollbar assembly back together, then cleco'ed it to the F-1231D's using the forward facing holes. Riveted the F-1231E's and F-01231F-2 to the F-1231A-FL, -FR, -AL, & -AR using LP4-3 and CS4-4 except where noted with a triangle per figure 2 and callout.
