Brief Description: Lower Fuselage forward of seat ribs part 2
Riveted all Step Rib Assemblies and the F-01212-L-1 & -R-1 to the F-01203A-1 per figure 1 reference page. Inserted temporary bolts to align the F-01202F-1 to the step ribs.
Riveted F-01202F-1 to the Step Rib Assembly angles per figure 1 same page. Riveted the F-01202F-1 to F-01212-L-1 & -R-1 and to the four step rib assembly ribs with the exception of four holes marked CLECO DO NOT RIVET in same figure. Final-Drilled #30 the F-01202F-1 to F-01212-L-1 & -R-1.
Installed 8 SB750-10, 7 SB500-6, 4 SB375-4 Snap Bushing per Figure 2 reference page into the holes in the bulkheads. Riveted HW-00014 to F-01202F-1 to the F-01202F-1 using 2 LP4-3 Rivets per the call out of figure 2 same page.
