Brief Description: Attaching Seat Ribs and Floors to Bulkhead
Riveted F-01225-R-1 to the #8 Rib and Pulley Bracket/Seat Rib Assembly using LP4-3 Rivets and excluding the one hole called out in figure 1 page 21iS/U-11. Riveted 4 K1000-08D nutplates using AN426AD3-3.5 rivets to the Pulley Bracket/Seat Rib Assembly and to the F-01225-R-1 Seat Floor. Riveted 1 MS21051L08 nutplate using AN426AD3-3 rivets to the #5 rib andF-01225-R-1 Seat Floor. Riveted F-1253-R to the bottom of the F-01225-R-1 using LP4-3 rivets excluding the two holes called out in figure 1 same page.
Bolted the F-1204R to the F-01204B-L using 2 AN3-12A bolts, 2 NAS1149F0363P washers, and 2 AN365-1032 nuts.
Riveted the left and right seat floor assemblies to the F-01204A-1 center section bulkhead using the rivets called out in figure 2 same page, LP4-3's, CS4-4's
