306TD Web Site
Date:  10-29-2021
Number of Hours:  6.00
Manual Reference:  23iS/U-07
Brief Description:  Installing Side Skins
Trimmed the tabs from the aft edges of F-01270-L-1 & -R-1 per detailed view of figure 1 reference page. Using edge breaking tool, broke the bottom and aft edges of both side skins.
Dimpled the nutplate holes around the triangular opening in F-01270-L-1 & -R-1 flush outboard. Riveted 10 K1000-08 nutplates each skin using CCR-264SS-3-2 rivets.
Tape holes marked with a triangle in figure 1 same page to prevent accidental riveting.
Using CR3213-4-2 CherryMAX rivets, prepped the rivets with oil and then Started Riveting the F-01270-L-1 & -R-1, F01270A-1 and F-1270D-L & -R, F-01255-L-1 & -R-1, F-01205B-L-1 & -R-1, and F-01234-L-1 & -R-1 to the fuselage per figure 1 page 23iS/U-10 using the CherryMAX rivets.
