Cleco'ed the W-1202-L Mid Wing Skin to the wing skeleton per Figure 3 page 17-02. Riveted the mid wing skin to the wing skeleton leaving open the 1st holes aft of the leading edge and the holes for the W-1216B per Figure 2 page 17-03.
Flipped the wing over and Cleco'ed the W-1201-R, W-1202-R, and W-1203-R Inbd, Mid, and outboard Wing Skins to the skeleton then riveted as called out in figure 1 page 17-03 and removed all remaining cleco's.
Cleco'ed the bottom flange of the two W-1216B-R Hinge Ribs to the W1202-R & W1203-R Mid and Outboard Wing Skins and Rivet the bottom flanges per figure 2 same page.
Inserted two W-1216 Hinge Bracket Assemblies through the openings in the W-1202-R & W-1203-R Mid & Outboard Wing Skins. Inserted Cleco's through the hinge ribs and the Hinge Bracket Assemblies into the W-1210-R Main Ribs. Cleco'ed the hinge ribs to the Rear Spar Assembly. Riveted the hinge ribs to the Hinge Bracket Assemblies, main ribs, and Rear Spar Assemblies as shown in Figure 2 same page.
