Began the airbox today. Found out that the mixture lever will interfere with cowl on left side, and tried a couple of ideas:
1. Rotate injection servo 180 deg to put throttle on that side. Result: no better clearance. 2. Put mixture arm at top, reverse with bellcrank. Complicated.
