Brief Description: Finished all Skybolt fasteners on lower cowl
Finished installing all Skybolt fasteners on lower cowl by doing the lower 6, 3 each side of air outlet. All fit well, whew!
In retrospect I might not use Skybolt at all on the lower cowl. All surfaces are flat, and the hinges would be just as easy (if not easier), and probably provide better support. But the Skybolts are fine too.
