Brief Description: Tentative location of left horiz hinge
Tentatively located and drilled the left hinge attaching the upper and lower cowl. Tentative because while I drilled all the holes 1" apart on the upper half, the lower half I drilled only 4 or so in case it's wrong. Drilled through the front to get the wire pin in and out. Too much hinge aft, interferes with Skybolt flanges, will fix tomorrow.
