Brief Description: Fit and measure trial fuel lines
Fit and measured two trial fuel lines in preparation for custom order. First, Adel-clamped an existing line from mechanical pump to fuel servo inlet to a motor mount. Then ran cheap plastic line from servo outlet to Red Cube fuel flow meter to check length. Also ran plastic line from Red Cube to injector spyder for its length (after cutting a hole in the baffling and fitting grommet).
