Finished connecting the last two pushrods to their end bearings...always a time-consuming task to get both washers fitted inside the enclosing arm. Did find a bit of a trick: apply lithium grease to the washers and stick them to the rod-end bearing. Then carefully move the rod-end bearing into the arm. With some luck, which I don't have, the washers remain in place and you insert the bolt. With less luck, one or both washers move out of place...but at least they stick to the enclosing arm surface and don't fall. Then you can push them into place with an awl or pick.
