Riveted together the elevator bellcrank after applying zinc chromate sacrificial primer to all sides of the pieces. Drilled extra hole for Dynon autopilot servo arm. Installed in fuselage, attached push-pull tubes (previously adjusted to proper length). Developed a good crick in my back bending over trying to get those washers in.
