Ralph Finch RV-9A Build
Date:  9-24-2011
Brief Description:  Cleaned, primed elevator push-pull tubes
Cut both elevator push-pull tubes to length. Cleaned outside of tubes with Extreme Simple Green and 99% isopropyl alcohol. Sprayed outside with zinc oxide primer. Applied boiled linseed oil to inside of tubes, left to dry.
