Brief Description: Extended Static line to fwd fuse
Extended the static line to the forward fuselage area where eventually it will connect to a steam gage altimeter and airspeed. Made 3 clips from Al sheet metal scrap (cleaned and Alodined two, forgot that for one) to support the static line under the main fuselage longeron. The clips don't squeeze or grip the line, just support it away from rivet shop heads, etc. Lotta work to get the clips re-riveted back under the longeron but I'm pleased with the result.
