Messed up the two brake lines from the firewall thru the center section: failed to account for total length with all bends, so cut short one side. So, started creating new ones by fully bending the copper wire I got before. I'll use that as a complete pattern, not a starting pattern, for actual bend.
Also practiced flairing ends with Rolo-Flair tool. Works well following instructions carefully.
