Brief Description: Finished brake fluid reservoir, installed Bonaco b
Finished installing the brake fluid reservoir, using short Al tubes for spacers instead of multiple washers.
Installed the Bonaco flexible brakes lines. However, in the process I discovered they do not use AN fittings. Sent email to some local builders about this. At this point I'll probably continue with their brake lines as-is, but I am now reluctant to use their fuel lines. I'll try bending the Al tubes per Vans.
Also researched and ordered a new fuel pump (EFII), the Andair fuel valve, and other misc. items.
Not a lot of physical work accomplished but a lot of research instead.
