Brief Description: Started placement of flap indicator
Started placement of flap indicator. Found the location on center flap bar arm to give full travel to linear potentiometer. Installed clevises and horn purchased at RC hobby store. Made a bracket to attach horn to and also attach to flap arm. Not sure this bracket will be final one, but it's a good start. It may need to curve around the flap tube a little more so as not to rotate; or, could use JB Weld to secure it, but then I'd have to grind away some powder coat on arm.
