Brief Description: Installed wear blocks for shoulder harness cables
Installed wear blocks F-6114B,C for shoulder harness cables on baggage bulkheads F-652 and F-751. Had to lengthen the slot on upper bulkhead, etc. Ground dips into lower bulkhead flange to give clearance to static, pitot, and AOA tubes. Always some custom work. Installed both bulkheads but I'll have to remove them soon to rivet the channel now attached with clecos.
