Brief Description: Riveted cabin frame assy, made light holder
Finished the cabin frame assembly F-631: riveted forward channels to straps with solid rivets, made F-732D angle and match-drilled, riveted F-631E plates, riveted aft channels with pop rivets.
Tried to add overhead baggage area lights to F-631 but couldn't come up with a good way of angling the lights to the baggage area. Instead, made two angles to rivet to underside of F-732A channel on which I'll attach the white LED strips I got from Autozone.
