Brief Description: Continued installation of static line
Made tabs to secure static line if aft fuselage, going forward from static ports. Drilled out two existing flush rivets and re-riveted with tabs in place (Image 1). Goes to a tee adjacent to the ADAHRS tray, where one line will terminate in the ADAHRS, the other line continues run forward. Drilled hole in beefy F-705 bulkhead to accept static line for run forward along longeron.
Secured static line in aft fuse
Connects to tee to fwd fuse and ADAHRS
Drilled 1/4" ID hole in F-705 bulkhead to pass static line fwd
