Brief Description: Finished left wing tip, returned to right wing tip
Finished squeezing rivets for the nutplates on the left wing tip and screwed onto wing with a little Boelube wax for initial attachment. Returned to right wing tip, which had the aluminum inner strip and pilot holes drilled for the nutplate screw hole. Clecoed right wing tip to wing, matched drilled holes to final size (#28 bit or so), brought back to work table and drilled all rivet holes using technique already described. Next: countersink holes and squeeze on nutplates.
