Brief Description: Riveted aileron attach brackets to wing
Finally, return to work! Sidetracked with several computer projects: first fiddling with hacks to the NSLU2 (using that as a 5 watt proxy server), then installing W2K and Xubuntu on a couple of freebie old laptops.
Oh yeah, the aileron attach brackets. Not pretty riveting but they're on. Shop heads are OK but the rivet set kept gouging the aluminum around the manufactured head.
