Brief Description: Cut and finished aileron-stick pushrods
Finally found the aileron bellcrank-to-control stick detail (DWG 15) and cut and finished (disk sander) the pushrod to size. Will spray a last coat of rattle-can self-etching primer on the outside and plan on using boiled linseed oil on the inside.
